Afficheur Oled des valeurs
un wemos et un afficheur Oled, et le tout tourne sous ESPHOME
connectique en GPIO 4 et 5 + GND et VCC ( mais 3.3V semble mieux )
et le STL : https://www.thingiverse.com/thing:2884823
esphome:
friendly_name: ESPHome retour Oled 2
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxx"
ota:
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Esphome-Web-"
password: "xxxx"
###rajouté une font dans le répertoire de home assistant
font:
- file: "fonts/ArialCE.ttf"
mqtt:
topic_prefix: esphome/e5406
broker: !secret mqtt_broker
username: !secret mqtt_username
password: !secret mqtt_password
text_sensor:
- platform: mqtt_subscribe
topic: domoticz/in/29
#Pzem/29
#radiateur/temp
on_value:
then:
lambda: |
id(Prod_text).publish_state(x);
topic: domoticz/in/100
#Pzem/29
#radiateur/temp
on_value:
then:
lambda: id(Conso_text).publish_state(x);
topic: domoticz/in/200
#Pzem/29
#radiateur/temp
on_value:
then:
lambda: id(Lixee_text).publish_state(x);
topic: domoticz/in/110
on_value:
then:
lambda: id(dimmer_text).publish_state(x);
- platform: template
internal: true
internal: true
internal: true
internal: true
i2c:
sda: GPIO5
scl: GPIO4
scan: false
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
update_interval: 15s
lambda: |-
const char * text = id(Conso_text).state.c_str();
const char * textprod = id(Prod_text).state.c_str();
const char * textlixee = id(Lixee_text).state.c_str();
const char * textdimmer = id(dimmer_text).state.c_str();
it.printf(0, 0, id(my_font), "Conso: %s", text);
it.printf(0, 16, id(my_font), "Prod: %s", textprod);
it.printf(0, 32, id(my_font), "ECS: %s", textlixee);
it.printf(0, 48, id(my_font), "Dim: %s", textdimmer);
